Looking for some insight and possible same experience.
2008 GMC Acadia
Steering assist will almost go away about 1/2 turn from steering stop either direction. Can forcibly steer through it. Steers fine straight or slight turn. Fluid is full and clean. First attempt to duplicate issue only occurred at about 1200-1500 rpm, however, have gotten it to fail at idle in park also. Belt is good and tension is ok.
Did not pressure test pump but our suspicision is a pump issue.
Has anyone else experienced this issue on these or like vehicles?
2008 GMC Acadia - Steering Questions
Arlin G. Sample
Greeley, CO 80631
970-352-5598
Greeley, CO 80631
970-352-5598
Re: 2008 GMC Acadia - Steering Questions
That's the way i would lean. Make sure there is an idle up when turning the wheel at a stop and i would look into tsb Bulletin No.: 06-02-32-013B.
Thanx Steve. I will check out that tsb when I get back to the shop.
Arlin G. Sample
Greeley, CO 80631
970-352-5598
Greeley, CO 80631
970-352-5598
