2002 Chev Trailblazer - Mode Door Actuator
2002 Trailblazer has intermittent popping in left side of dash , to the right of steering column. GM tsb leads to replacing mode door actuator, but says special puller required. epair dont show any illustrations. Anyone been there, can it be replaced w/o the special puller. Thanks.
Re: Trailblazer mode door actuator
The special puller allows replacement of the mode door actuator without removal of the dash assembly. Tool is worth the cost. Something about 150-160 dollars. Kent Moore Tool only, at least so far.
Thanks Tim..was hopin for a way around usin the tool. Customer is leavin for points north on vacation and is worried about loosing heat. Lack of prior planning is now a crisis!!
I heard that!Jeff @ Able Auto wrote:Lack of prior planning is now a crisis!!
Re: 2002 Chev Trailblazer - Mode Door Actuator
Haven't ran into one of these yet. Great another tool needed.
