No Maintenence
- nickscarcare
No Maintenence
There is no maintenance schedule for this vehicle 1J4GW38S82C233589. Good thing the owners manual is in there. Lady wants to keep following it.
Re: No Maintenence
I easily found maintenance for this. Can you describe where and how you were looking?
- nickscarcare
Re: No Maintenence
I click on the maintenance tab on the order like I always do, says no info available. I can get labor, parts and fluids. 7.0.11
Re: No Maintenence
OK. I went directly into ProDemand and it's all there. I've never seen that issue before, but in the future IF you encounter it again, go directly to ProDemand and take a look. may be some linking error.
- nickscarcare
Re: No Maintenence
I went to Identifix. Guess I didn't think of trying to go there seperatly.
- nickscarcare
Re: No Maintenence
I just tried that for the same vehicle, still no record.
Re: No Maintenence
Hmmm. Maybe it's one of the qualifiers. Can you provide submodel, drive and engine?
- nickscarcare
Re: No Maintenence
2002 Jeep Grand Cherokee Sport, 4.0L, 4WD
Re: No Maintenence
Thank you. It appears there's a mapping issue for the qualifier 'Sport'. Both other options provide results. In the future and for best results when this occurs, click the Feedback button so the powers-to-be will be alerted. I sent a feedback while I was there confirming the missing link.
- nickscarcare
Re: No Maintenence
Where is the feedback button?? I did not see it.
Re: No Maintenence
When in ProDemand, it's a little tab down on the lower right.
- nickscarcare
Re: No Maintenence
Ok I see it now, on mine its in the upper right, thank you.
