Page 3 of 3
Re: Email History Invoice: Re: Manager SE v 6.6.8
Posted: Tue Aug 18, 2015 1:43 pm
Johnny5 wrote:Did you know that in Manager SE, if you go to the history screen, and open a historical invoice, then select File (at the top left), then Email, the software will examine that customer, if there is an email address on file, the Invoice from History will be packaged up into a PDF file and sent to your email client to ultimately send to the customer? If there is no email address, the system will prompt you for an email address, use that, send the email, and save the email to the customer record.
I just picked up on an important part of this. This action fills in the email address you used into the management system field for email. This 'backfill' if you will occurs when emailing an active document such as an Estimate, RO or Invoice as well as history documents. VERY NICE!
Posted: Tue Aug 18, 2015 2:06 pm
by BGNOBERT
We are running Manager SE 6.5.57
Are we suppose to update with this? Or is it for those with other problems of software etc...
I thought Manager SE updated itself when needed?
Posted: Tue Aug 18, 2015 2:09 pm
by timbre4
Yes, the SE version has an Auto Updater function. However, as recent forum posts here will show, we simply cannot update everyone at once. We have a forthcoming update which will be metered out to shops in groups and the SE support page is offered to anyone who is experiencing a specific technical issue or that simply wants to get updated sooner than later.
Posted: Thu Aug 20, 2015 7:07 am
by sbcauto
I See I Can Download Manager Update 6.69. I Saw Good New For 6.68. Anyone Know What Is Different In This Update? I'm Still Running 6.5.57. Thanks
Posted: Thu Aug 20, 2015 7:37 am
by Rich
What 6.6.8 brings to the table is posted as the first post in this topic. You will like it.
Posted: Thu Aug 20, 2015 7:47 am
by Silky7
6.6.9 (A.K.A. the Ric update
) primarily addressed a few minor issues found in 6.6.8. If you have 6.6.8, mostly likely you will not need to update. However, if you're still in the 6.5.x builds, I think most users would recommend the change for the added features.
Posted: Thu Aug 20, 2015 7:58 am
by sbcauto
I Noticed Today That Manager Update 6..69 Is Now Available For Update. Has Anyone Updated To See What Difference Between 6.69 & 6.68?
Should I Update As I'm Still Running 6.5.57?
Thanks
Posted: Thu Aug 20, 2015 8:04 am
I am running 6.6.9. Not much difference between 6.6.8 and 6.6.9 other than a few minor flaws corrected. Big difference between your version and 6.6.9.
Posted: Thu Aug 20, 2015 8:57 am
by timbre4
When things calm down a little, we will update the "What's New in This Release" section of the SE home splash page.
Posted: Mon Oct 12, 2015 7:09 am
by Crescentbunny
We love the update, thanks everyone!
Posted: Thu Oct 29, 2015 11:17 am
by sbcauto
Does The New Update Allow Me To Transfer a Revison To Estimate Without Changing My Esimate To A Repair Order?
thanks
Posted: Thu Oct 29, 2015 11:35 am
I have 6.6.9 and I can transfer a revision to an Estimate and it stays an Estimate.
Posted: Thu Oct 29, 2015 12:10 pm
by Jeff @ Able Auto
You have to have at least one line on the est on mine 6.6.10. I start all estimates with a courtesy inspection line. I forget to do that and transfer a rev to a blank est screen it turns into an RO.
Posted: Thu Oct 29, 2015 2:11 pm
by rhillig
Posted: Fri Oct 30, 2015 8:55 am
by Silky7
rhillig,
Just a couple things to throw out there regarding this. Remember if you have any line items on the Estimate first, it won't autoconvert. You might consider a quick CJ that you get in the habit of using to add some notes or whatnot. Also, the good news is in 7.0 the comments you add when creating an appointment will transfer to the order by default, creating a note. This little change to the workflow should be enough to keep your estimates as estimates.
Posted: Fri Oct 30, 2015 9:05 am
by rhillig
Silky7 wrote:rhillig,
Hmmm, if I could only get the gremlin to do that....................
Posted: Fri Oct 30, 2015 9:37 am
by Silky7
I think with the new scheduler, he'll find it easier to adjust the workflow.
Hopefully.
Posted: Fri Oct 30, 2015 9:55 am
by rhillig
Silky7 wrote:I think with the new scheduler, he'll find it easier to adjust the workflow.
Hopefully.
Well, he just adapted to texting a couple years ago.....we have yet to get him into email yet.....there might be hope.
