2001 VW Beetle - Dsl Poor Power C17964 FIXED
Princeton Auto
Post by Princeton Auto »
The vehicle starts and runs smoothly, but no power. Acts as if there is no boost from the turbo. That is not the case! Plenty of boost from the turbo, but it doesn't seem to be breathing well. Runs as if the exhaust is clogged up. Code 17964 -- Charge Pressure Control or Control Limit Not Reached is present. All of the diagnostics related to this code have been performed with no definitive result.
Any Ideas?
Michael
Princeton Auto Service Center
Re: 2001 VW Beetle --Poor Power
Check the intake and the EGR ports. These clog all the time and could cause this breathings issue. The turbos sometimes fail to vary, even though they spin. Control rods for the wastegate and vacuum lines to the system often fail. These are real fun. Good luck.
Princeton Auto
Re: 2001 VW Beetle - Poor Power C17964
I forgot to mention, this vehicle is a diesel.
Michael
check tech service bulletins 2307-02 and 2107-94 the last one makes the most sense. good luck and have fun........
Princeton Auto
Re: 2001 VW Beetle - Poor Power C17964 Fixed!!
I checked and rechecked this vehicle. I finally purged the injectors again, and all the power came back. Vehicle runs excellent. OTD (Out the Door)
Customer picked up. Thanks for your help.
Michael
Re: 2001 VW Beetle - Dsl Poor Power C17964 FIXED
thanks for posting the fix. did you think that the fuel may be contaminated. i remember years ago mercedes had an issue with the inside coating of the tank melting.....
Return to “VW / Audi”
