Sticky Category on R.O. Using Save?
MURRI513
Post by MURRI513 »
Since the last update to 7.3 the category is "sticky" & unless you physically change it on Category Profit Summary it shows as unassigned. When it showed up as "none" prior it was easy to see you missed an entry. Also when searching inventory it will automatically only search in the last items category you were in i.e. input filter, then look for a screw it only searches in Preventive Maintenance not the category not the entire inventory. Can we please go back to the old way.
Re: Sticky Category on R.O. Using Save?
We've identified an issue with the Part Item category not resetting correctly when using the Save button. We'll get that fixed in a future update.
