Active Spell Check in Recommendations
We noticed today that active spell check is not working when typing in the body of recommendations. F2 spell check does work here, just not the active check. Is this by design?
Re: Active Spell Check in Recommendations
There are certainly a few areas the spell check function still needs cleanup. We plan to implement it in the Vehicle Memo field and Appointment Comments, as well as cleanup function in some existing areas, like the Recommendation area. First though, we're switching out some legacy controls for newer ones all around the app, which will then allow us to fix integration into these fields faster.
Can you make the Spell check auto correct the words? Somehow the very obvious red lines under mistakes are not obvious enough.....
- Johnny5
This is fixed in v 7,2. It won't automatically correct words, there are too many variables to manage.
