SE 7.3 Can't Get Update To Work
I see many shops have the latest update. I have been looking forward to using it, however I can't seem to update my system from 7.2.9. I found a link on M1files. com, downloaded and installed the update even restarted my computer but still do not have the latest version. Any idea how I can get it?
Re: SE 7.3 Can't Get Update To Work
If you've already attempted a manual installation and didn't succeed, it's time to call into Tech Support.
Thank you
I called Tech Support, they walked me through the setup. The update is great, however I can no longer e-mail from within the program. I have to print,scan and then e-mail, have tried shutting down just Mitchell and also restarting the computer numerous times. I called Tech Support and was told the update does not recognize or work with Outlook. Has anyone else had this problem? It was working before the update.
We use Manager with Outlook every day. No problems.MURRI513 wrote:I called Tech Support, they walked me through the setup. The update is great, however I can no longer e-mail from within the program. I have to print,scan and then e-mail, have tried shutting down just Mitchell and also restarting the computer numerous times. I called Tech Support and was told the update does not recognize or work with Outlook. Has anyone else had this problem? It was working before the update.
Perhaps the support person misunderstood your problem.
Yes, we must apologize. There was definitely some confusion on the agent's part. The integration with Outlook was not changed.MURRI513 wrote: I called Tech Support and was told the update does not recognize or work with Outlook. Has anyone else had this problem? It was working before the update.
*Edited for Update.*
Sorry, after reviewing your support recordings it appears you are likely experiencing a system issue beyond our scope of support. It appears the Windows MAPI isn't working correctly on the system, as evidenced that it's not working from other applications on the system: One thing you might check that is fairly simple is to make sure you're not running at different user contexts. That is, if you have Outlook set to Run As Admin, you should try running Manager the same. If Manager is set to Run as Admin and Outlook is not, you might try Manager without that setting. To Run as Admin temporarily, you should be able to simply right-click on the icon.
Thanks for looking into it, I will call our in house tech support firm.
