Is anyone else exeriencing this?
If you apply a Canned Job with Charged Hrs. & a Labor Total pre-configured to a RO then adjusts the Charged Hrs. the Labor Total does not adjust accordingly. Shouldn't it adjust? It does if you manually add a Labor line fill in the fields and go back and adjust the Charged Hrs.
Labor total not updating with charged hours
- megoff
Re: Labor total not updating with charged hours
Great question Dan, one of the biggest reasons the labor total won't update is if the labor item is set for "Non-Standard Labor Rate" within the item. This happens quite a bit within canned jobs as most shops are trying to set the cost of the job.
