Accessing Shop Reports [ProDemand screen]
The Shop Reports section of the ProDemand website does not work with no ETA given. The main reason I signed up for ProDemand was to be able to access shop reports remotely.
Re: Accessing Shop Reports [ProDemand screen]
I never knew you could access anything remotely.
Welcome to the form and thanks for posting. Shop Reports went into active service in January 2021.exclusiverepair wrote: ↑Tue May 03, 2022 10:39 amThe Shop Reports section of the ProDemand website does not work with no ETA given. The main reason I signed up for ProDemand was to be able to access shop reports remotely.
Should be working, perhaps some configuration work not completed?
Configuration video: https://youtu.be/eChKA0ydVmo
1. You are using Manager SE (source of reports)?
2. Do you see the Shop Reports listed at the bottom of your ProDemand home screen modules list? [column down left side]
It's selected Manager SE reports; most SE users also have ProDemand so it made sense to just add a module there and add some security to it.
