Tech Worksheet has wrong decimal places and is rounding
rfmjohn
Post by rfmjohn »
Hi there! We have a shop that has been using Manager SE for years and it has been working well. Recently, we had to replace a dying PC with a new one, so we had to reinstall the software. We've got everything working great again except for one odd thing: on the Tech Worksheet, for the "Charged Hours" column under Labor as well as the "Qty" column under Parts, the numbers are all just a single digit with no decimal places instead of the normal x.xx numbers.
So, for example, on all of the other PCs, when they print a Tech Worksheet, it will look something like this:
Code: Select all
Parts:
K123456      Sway Bar Link Or Kit      1.00
K234567      Blah Blah Liquid          1.75
Labor:
STABILIZER BAR CONTROL LINK - Remote & Replace - Both Sides        0.60
4 Wheel Alignment                                                  2.00
                                        Total Hours Charged:       2.60
But on this one newly installed PC, the same exact report will look like this:
Code: Select all
Parts:
K234567      Blah Blah Liquid          2
Labor:
STABILIZER BAR CONTROL LINK - Remote & Replace - Both Sides        1
4 Wheel Alignment                                                  2
                                        Total Hours Charged:       3
All are printing to the same Brother printer. All are running Windows 10. All are running the latest Manager SE. I've double-checked that the same report is selected in the settings.
I assume it is some weird Crystal Reports engine issue. Any thoughts? Thanks!
megoff
Re: Tech Worksheet has wrong decimal places and is rounding
Post by megoff »
Hello rfmjohn and welcome to the Forum,
Traditionally when a report prints this way with rounding to no decimal places it has to with the formatting within Windows. As these settings are a little strange to walk through please feel free to give Tech Support a call and let them know you're having an issue with rounding when printing. We can get this corrected for you fairly quickly.
rfmjohn
Post by rfmjohn »
Ok, so, I solved my own problem -- and only because I vaguely remember this happening with an app that I wrote 15+ years ago that used Crystal Reports.
For some reason, Crystal Reports sometimes gets confused about the Windows Region settings. I went and looked on this machine and Region was set to "Recommended: United States" -- just as it should be. I changed it to "UK" and then immediately back to "United States" -- and now everything prints properly.
So, problem solved. Thought that I'd leave the thread here in case someone comes across this issue in the future. Thanks.
megoff
Post by megoff »
I was assuming it was something to do with the region settings, that's normally where issues can arise within some reports.
rfmjohn
Post by rfmjohn »
Yeah, it's been a bug in Crystal Reports for at least 15 years. I had a vague memory of it happening and then finally figured out -- then came back to post about it and we happened to post at the same time. :)
Thanks.
Thanks for sharing this here.
nickscarcare
Post by nickscarcare »
Love the blah blah liquid
