Is IMC A Catalog I Can Add?
I saw in someone's screen shot that IMC was a catalog that was added. Not sure if this is on a wide release or if it still in testing.
Re: Is IMC a catalog I can add?
I went to the IMC website and found this in the FAQ's.
Q. Is IMC Catalog available thru Shop Management Systems?
The IMC catalog is available via major Shop Management Systems through Wrenchead, including:
Mitchell 1
So the answer is yes. Make sure you have the Wrenchead catalog on your system and contact your local IMC to get credentials.
Mitchell 1
Re: Is IMC A Catalog I Can Add?
IMC would be added using the Nexpart integration; setup vendor record with IMC credentials and Nexpart link.
When Nexpart button is clicked it would display IMC catalog page.
