Returns
dtstire
Returns
Post by dtstire »
Is there any way to manually adjust entries to the Inventory Returns report/object? For example, if I accidentally return something that needs to stay in the shop, other than "returning" a negative quantity, is there any way to edit these lines?
Any help would be appreciated!
Re: Returns
You can manually adjust the item via the Inventory window. When you do, you get a window to enter the reason. There is also a report to show these manual entries and their reasons.
CARTECHPLUS
Re: Returns
Post by CARTECHPLUS »
Also, If you just want to quick change the physical count you can pull down the inventory tab and select inv. transactions and physical count. I use this if its just a quick change as this function does not require you to enter a reason. :-)
