The wiring schematic/component location regarding the rear defroster circuit for a 1999 Olds Alero GL is not correct. It shows the rear defroster relay location as inside the vehicle, when in fact it is located in the underhood fuse/junction block.
Thanks,
Tim
1999 Olds Alero Rear Defrost Schematic
Re: 1999 Olds Alero Rear Defrost Schematic
If you are useing OD5.com, you can make a note in the tip system and the whole world will have acess to your find and might save someone a good bit of trouble. Also, they look at this type of post in the tips and will check and correct the repair info too. Thanks for finding and pointing this out.
Welcome to the forum and thanks for your posts.
I'd recommend sending this to Product Support as they do not monitor this forum. There is a link in this section or use the info below:
Please call 888-724-6742 and follow the prompts OR use this email form: http://www.buymitchell1.com/form/productsupport.htm
