Problem When Adding Canned Job
When adding a canned job that contains a part kit with optional parts choices and parts with ALT part numbers, the program adds each ALT part number as an actual part on the order. These parts can only be seen on the tablet and do not show up on the desktop. WEIRD.
- Auto Repair Coach
Re: Problem When Adding Canned Job
I believe that software is "alive". It seems to do things occasionally that were not intended for it to do. Unfortunately, most times it is something wrong.
I'll put it a report.
John Burkhauser
BOLT ON TECHNOLOGY
BOLT ON TECHNOLOGY
This is an odd set of circumstances that would be difficult to test. I was quite surprised when I had 12 parts in addition to the correct one. We use Alt part quite extensively here.
If it's breakable, I'm likely to do it.
- Auto Repair Coach
I hear you Ric. I break things good too!
John Burkhauser
BOLT ON TECHNOLOGY
BOLT ON TECHNOLOGY
