Deleting Appointments?
When a customer calls and cancels an appointment and then when I delete the estimate from WIP, it stays in the scheduler under appointments tab and sends a text reminder to the customer of their appointment even though they cancelled. I have to make sure to go in and delete it from scheduler as well as the estimate on WIP. Is there a setting I can change so when an appointment is deleted off of WIP it also gets deleted from scheduler?
Re: Deleting appointments
There's isn't currently such a mechanism. The best bet currently would be to edit the Appointment state and switch it to Cancelled before deleting the estimate. Doing so should will prevent the customer from getting a reminder from our CRM.
This should be fairly quick from the WIP by right-clicking the Estimate, selecting the appointment button, then changing the state in the upper-right corner. Click on open Estimate from there, save the changes when prompted and remove the estimate.
Re: Deleting Appointments?
I agree it is another click (or three) that I would like to think are not needed. I've just gotten in the habit of removing the estimate from the WIP screen and then going into the scheduler to also delete the appointment itself. We don't get many cancellations so it isn't a big deal, but the disconnect between manager and the scheduler has always frustrated me a bit. Kind of like when an appointment is made under a certain name, but when the car gets dropped off the name changes. Once you change the name in manager, if you want it to match you also have to change the name on the scheduler.
+1BERGMANS1 wrote:I agree it is another click (or three) that I would like to think are not needed. I've just gotten in the habit of removing the estimate from the WIP screen and then going into the scheduler to also delete the appointment itself. We don't get many cancellations so it isn't a big deal, but the disconnect between manager and the scheduler has always frustrated me a bit. Kind of like when an appointment is made under a certain name, but when the car gets dropped off the name changes. Once you change the name in manager, if you want it to match you also have to change the name on the scheduler.
Is there a resolution yet for this? I would like to delete an appointment off of the WIP screen, but cannot find an option.
Hello, and welcome to the forum (as a poster).arbm wrote:Is there a resolution yet for this? I would like to delete an appointment off of the WIP screen, but cannot find an option.
Appointments are not visible on the WIP. They are a separate entity from Orders, which are what appear on the WIP. So if you have an estimate, RO or invoice you're trying to remove, simply open it, then go to the File menu > Edit > Remove Order.
Hope this helps.
