TIP: One Category Report?
- nickscarcare
Is there a report that searches just for one category. So for instance there is a tire recall, and I want to find out what customer I have sold tires to, so I can go in and look up to see if they have tires on that list? Or do I have to go through history to find this?
- murraymotive
Re: Category report
You could hit F4 and enter a wildcard + keyword.
For instance: %Bridgestone
This will give you a report of sorts in that you can see posted invoices with your keywords. It is a bit cumbersome to look at more than one invoice, but this method does work.
Do you use Bolt On's Pro Pack by chance? If so, I can show you how to make the exact report you want.
Re: Category report
If there is a recall, enter the part number(s) one at a time into the Part Number Search report; or you could enter a full / partial description to build the report that way.
Reports -> Management Tab
- fortknoxx
Re: Category report
for futures.....
I use the customers last name as a po for my tire, wheel, lift kit. I had a wheel recall for Moto Metal 909 skull wheels in 8 lug. When the vendor sent me the recall notice and a copy of the invoices I had purchased the affected on. There was the customer last name. Bazinggg.
- nickscarcare
Re: Category report
The tire warehouse I bought these from told us that the people will notify us, that is why we fill out the DOT cards. They do not have those records. We did get the list. The other thing I did wrong, was I put in the part number from my warehouse, not the manufacturer number, no big deal just had to look up that size to get that number. Thank you for the replies, I knew there had to be a way.
