Import Time
Discussion area for the new Time Manager including Job Clock and Shift Clock
ShopManTim
Import Time
Post by ShopManTim »
How do I export the technician's time to the RO? Say a tech worked on Joe's car for 1.45 hrs. Is there a way I can export that info to the R?O without manually having to do so?
Re: Import Time
I'm not sure I completely understand the question. If the technician is logging into the Time Manager job clock and ultimately marking items complete, the line on the RO is updated to match. *Edited for clarity* The Actual Hours value is what is updated.
ShopManTim
Re: Import Time
Apparently there is a setting I have missed because, ok, I just completed a job taking .49 hr. I had hoped (as an experiment) that when I mark the job as completed it would update the actual time on the RO in the WIP screen but it did not.
Re: Import Time
It does update the Actual Hours on the line item in the RO once completed. There is no special setting for that. You mention the time on the RO in the WIP - there is no such thing. This leads me to wonder if you're referring to the Charged Hours? That is not something the Time Clock will ever modify.
The value changed by the time clock entry so we're on the same page:
You can see I didn't allow the clock to run very long in this case. :)
ShopManTim
Re: Import Time
SO what you are saying then is that I need to take the actual hours and put it up in the charged hours? It appears that this step is what I am missing. I had somehow naively assumed that the time clock would automatically place the actual hours in the charged hours. If that is the case, then moving forward I need to pay attention.
Thanks for the explanation!
Re: Import Time
ShopManTim wrote:
Mon Sep 25, 2023 3:26 am
Understood. Glad it's clarified now. For the record - we'd never change the charged time based on technician time. First, it's not legal to deviate from the estimate in several states in the event a technician takes longer than expected. Second, it's not a good business practice to reduce the charged time just because you might have a rockstar technician completing everything ahead of book time.
Return to “Time Manager”
