2000 Chrysler Sebring - 2.5L Auto Shutdown?
VEHICLE WAS BROUGHT IN FOR CHARGING SYSTEM ISSUES, DIAGNOSED BAD ALTERNATOR. CUSTOMER COULD NOT AFFORD, I CHARGED THE BATTERY AND NOW THE CAR JUST CRANKS, AUTO SHUTDOWN RELAY IS ENGAGING, ANY THOUGHTS WOULD BE GREAT
- brother bubba
Re: 2000 Chrysler Sebring - 2.5L Auto Shutdown?
Check camshaft position signal. erratic signal will show up as "YES" on scanner but will not sync injectors. seen this twice.
Have u had ur scannor on it and what do u see. Do u have no spark no fuel is the fuel pump working.
This vehicle did not have a cam sensor. found bad ground auto shut relay circuit
