2000 Chrysler Sebring - No Spark To Plugs FIXED
Posted: Tue Jun 16, 2009 2:02 pm
by crownvic
No spark to plugs; I have injector pulse, crank signal, cam signal rpm, signal and i replaced the distributor.
Re: 2000 Chrysler Sebring - No Spark To Plugs
Posted: Tue Jun 16, 2009 4:43 pm
by prestigeauto
Whats the engine size? Is it a convertible? If it has a distributor then is the coil inside the distributor?
Posted: Wed Jun 17, 2009 4:28 am
by crownvic
It is a convertible with a 2.5 engine coil is in the distributor .I replaced the distributor.
Posted: Wed Jun 17, 2009 8:01 am
by prestigeauto
Looking at the wiring diagram you need power from ASD relay, 5 volt supply, 2 grounds, coil driver(from PCM) grounding the coil and a CMP signal. I assuming your missing one of those signals.
Posted: Wed Jun 17, 2009 8:54 am
by crownvic
i have cam signal on my modius when cranking nothing coming out of the coil.
Posted: Wed Jun 17, 2009 11:32 am
by prestigeauto
Best to use a lab scope.
Posted: Wed Jun 17, 2009 11:41 am
by prestigeauto
Normally you dont need a cam signal to start. Just to run correctly.
Posted: Thu Jun 18, 2009 3:26 am
mmmmmmmmmmm modis reading but coil not firing. see if it's recieving impulse and if it is check for broken wire or faulty anti theft module. i've run into kill switched that have been there from previous owners and are somehow accidently switched.
Posted: Thu Jun 18, 2009 1:51 pm
by crownvic
Thank you for all your help.Ifound a ground wire broke in the harness runs good now.Thanks again,and god bless
Posted: Thu Jun 18, 2009 5:01 pm
by prestigeauto
Good to hear you fixed it. Which ground wire out of curiosity.
Posted: Fri Jun 19, 2009 2:26 am
THANKS FOR POSTING THE FIX..........yes i know i'm yelling. i want it to be known i appreciate the fix being posted.
Posted: Thu Jun 25, 2009 2:15 pm
by crownvic
It was the ground wire from the front of the head to the distributor.
Posted: Mon Jul 13, 2009 8:38 am
by Stewart Levy
Amen!
