2003 Mitsubishi Eclipse Spyder GS - No A/C @ Idle?
- John C.
At 1500 RPM A/C works fine, but when at idle blows only warm air.
System is fully charged (not over or under – we just did it ).
We’re guessing compressor.
Any ideas?
Any ideas?
John C.
- fortknoxx
Re: 2003 Mitsubishi Eclipse Spyder GS - No A/C @ Idle?
does it have a comp cut off switch? is the comp shutting off, or is it still engaged? is the blower fan blowing at a constant speed?
- crmeyers
Need more info than that...high side and low side pressures at idle and at 1500, and ambient temperature would be helpful.
- John C.
Nope to the cutoff switch, compressor is staying on, fan is working properly.fortknoxx wrote:does it have a comp cut off switch? is the comp shutting off, or is it still engaged? is the blower fan blowing at a constant speed?
Will answer after lunch.crmeyers wrote:Need more info than that...high side and low side pressures at idle and at 1500, and ambient temperature would be helpful.
John C.
- John C.
48 degrees inside at 1500, blowing warm air at idle.crmeyers wrote:Need more info than that...high side and low side pressures at idle and at 1500, and ambient temperature would be helpful.
1500: high side 150, low side 25-30, at idle: high side 150, low side 55.
John C.
Is this what the car came in for? Did you do anything other than a recharge? Do you check for sealer?
- John C.
Yes, that is why it came in. Mark disconnected the low side pipe and "looked inside for any s..." said it was clean. He says he saw no evidence of sealer anywhere.ricmorin wrote:Is this what the car came in for? Did you do anything other than a recharge? Do you check for sealer?
John C.
- fortknoxx
is this your true customer, or just one that comes to you when shadetree can't fix it? How long has it been doing this? Anything replaced before this happened (by you or some one else)? We might need to quiz the customer as to what and when. Anything look new or stripped? Just throwing out some ideas here.
This is John C., on Mark's computer.fortknoxx wrote:is this your true customer, or just one that comes to you when shadetree can't fix it? How long has it been doing this? Anything replaced before this happened (by you or some one else)? We might need to quiz the customer as to what and when. Anything look new or stripped? Just throwing out some ideas here.
Regular customer, although cheap, claims we're the only ones who've worked on his car since December of 06. I do believe him.
Been doing this for at least a few weeks, he said he's been putting it off (did I mention he's cheap?).
Mark is pretty certain it's the compressor, but it seems the only other thing it could be is the expansion valve. If we were sure it was the valve, he'd replace it. Knowing him, and he's already said so, if it's the compressor he'll just rev it at idle, that is of course until the compressor craps out (if that is the problem).
- a&mauto
Whats the air temp inside the shop? If its anywhere near 100 your high side pressure should be over 230 at 1500 rpm's. If the expansion valve was stuck wide open I doubt it would pull the low side down to 25. A long distance guess would be compressor. If you do the compressor you would want to replace the exp valve anyways..................John C. wrote:48 degrees inside at 1500, blowing warm air at idle.crmeyers wrote:Need more info than that...high side and low side pressures at idle and at 1500, and ambient temperature would be helpful.
Yup. Compressor and expansion valve. Should cover it fine. Compressors not cheap...may scare him off.
i'd also slam a drier into it. shot gunning it may go against your grain (it does mine) but with these a/c systems i generally replace as a package. years ago i'd clamp off high side hose after the port to see how quick pressure would max out. not anymore, just r&r. way to many issues just replacing one of these items especially on a customer like this one seems to be. you're going to be held hostage if you try to save him money. it's a loose loose for you unless you shotgun it.
Make sure you have good air flow across condensor. Set a fan in front of car and force air across condensor at idle and see if it makes a difference. Check for debris between condensor and radiaor also make sure fins aren't flattened out.
Arlin G. Sample
Greeley, CO 80631
970-352-5598
Greeley, CO 80631
970-352-5598
- John C.
Thanks Arlin, and everyone else. I'd say we're all in agreement, and "customer" (note the "" marks) did exactly what was expected - "gonna rev it at red lights".
John C.
what a boob..........i'll bet lunch he'll decide to up the rpm even more. i'd love to see him at a light either doing a torque stand or drop it into drive (or side step the clutch) when the light turns green. idiot.................
- John C.
Not to mention, that he has a toddler's seat in the back. Can't even shame some people into doing the right thing.steven kiser wrote:what a boob..........i'll bet lunch he'll decide to up the rpm even more. i'd love to see him at a light either doing a torque stand or drop it into drive (or side step the clutch) when the light turns green. idiot.................
As a non-tech, it boggles my mind the condition of so many of the cars we see, and then you see the kid seats in the back.
Got a little justice last month. Hemmed and hawed about putting this person on the mailing list back in January of 08 when we opened, but in the end I decided to add them. Similar to the above mentioned "customer", plus he's one of those - "I don't want to put any money into it, I'm getting rid of it within a month or two" kind of people. Anyway, had (note "had" it'll make sense later) a Pilot that a quick lube place or dealership ruined the oil pan. First time he's contacted us, since we opened. Came in with 109,561 miles on it, we replaced the oil pan, and I put in recommendations and verbalized:
"(5/13/2010) Has 105,000 mile scheduled maintenance service been performed? This service includes timing belt/water pump replacement. This vehicle is equipped with an interference engine, if the timing belt were to break, serious internal engine damage may occur. Regular maintenance is the key to dependable performance, reliability, and MAXIMUM FUEL EFFICIENCY."
Got a call from him while he and the family were on vacation in PA - guess what happened?
John C.
Ooo. Ooo. Lemme guess.
He let you do all the maintenance and he was just calling to tell you that he made it there just fine and how HAPPY he was.
Am I close?
Am I close?
- John C.
Exactly, and I was so glad to hear it, I slept like a baby that night.ricmorin wrote:Ooo. Ooo. Lemme guess.
Am I close?
John C.
wait, wait before you answer. how about it was your fault because "you're the expert and never should have allowed him to drive away knowing that this would happen" think this is way out there? if it hasn't happened you haven't been around long enough, just wait. i had a person file against me one time because i allowed his vehicle to leave my shop even though he signed a waver acknowledging that driving it would cause catastrophic engine damage. it was thrown out, even though he was a "victim".....ricmorin wrote:Ooo. Ooo. Lemme guess.
Am I close?
- John C.
No Steve, surprisingly he wasn't mad at us, in fact he said he was having it towed all the way back to MA and wanted us to replace the engine. But - it never showed up and haven't heard from him since. Guess what? I'm okay with that.
He should have never made the cut, but then again just about everyone who didn't has found us anyway. I was in the lot after we'd been here a few months, and one of "them" is driving around the complex reeeaaalllllyyyyyy slow looking all around. I literally ran into the side door, hoping not to have been spotted, and I think I pulled it off. But, who comes waltzing in the door last summer, said, "I had a hard time finding you guys". (We hear that more than we'd like.)
John C.
