2004 Volvo V70 2.5t Cam Seals FIXED
Posted: Mon Jan 07, 2013 12:30 pm
by erlesauto
Any tips on doing cam seals 2.5t with vvt.
Re: 2004 Volvo v70 2.5t cam seals
Posted: Mon Jan 07, 2013 1:48 pm
I would make sure the breather isn't plugged first. If this is the first time you've pulled a vvt pulley i would follow the timing belt guide. You need a tool to lock the cams. It may be the vvt pulley leaking as well.
Posted: Tue Jan 08, 2013 6:15 am
by erlesauto
Cam gears move back and forth approx 3/4- 1" suppose thats not good
Posted: Tue Jan 08, 2013 7:28 am
by Pauls Automotive
I believe that is normal. With no hydrolic pressure in them they can move free. We have done a few of these and they all ove free. Folloow the reassebly procedure very closely. Also as Steve mentioned maked sure they are not leaking as we have run into that as well.
Re: 2004 Volvo V70 2.5t Cam Seals
Posted: Tue Jan 08, 2013 1:04 pm
Again, you need to be extremely careful when doing this. You can get away changing a timing belt if you'r super careful without any special tools. HOWEVER if you take gears off they need to be set to factory specification. The outer gear is set up , locked to the hub, belt is installed and than gear bolts are loosened and hub set. If it's not done correctly you'll have a power issue.
Re: 2004 Volvo V70 2.5t Cam Seals FIXED
Posted: Wed Jan 30, 2013 11:03 am
by erlesauto
Replaced Leaking VVT units and cam seals. Bought tool off Ebay, works like a charm
by timbre4
Hooray! Thanks for posting the resolution.
Posted: Thu Jan 31, 2013 2:25 am
My tool sits and collects dust but once or twice a year when i need it i have it. If you don't need to remove the gear and are real careful the belt can be replaced. I've had more than a few but less than a bunch come into my shop with power issues and a fuel mileage drop after another shop changed the belt.
