2016 Ford Flex - Wearing Tires?
92zman
200 Club: Major Contributor
Post by 92zman »
We have a customer that has a 2016 ford flex and we put tires and did a alignment 14000 miles ago and now the tires are warn out. In the front there is very little tread left and worn more in the middle of tire than the rest. Tire psi is 35psi. The rears are cupped really bad. Any ideas. Read in a forum then they are bad on tires.
Re: 2016 Ford Flex wearing tires
Have you, or the customer, tried XL tires? The Michelin Defender LTX M/S comes to mind and it's available in at least on of the sizes for a Flex (235/55R19 105H XL). It may be a bit more noisy but all depends what was on it in the past...may not notice difference at all.
92zman
Post by 92zman »
This is what we put on it for tires 255/45R20 Y XL TP GTZ AS2 BLK_ / TIGER PAW GTZ AS2
nickscarcare
Re: 2016 Ford Flex - Wearing Tires?
Post by nickscarcare »
Tire rotation is key, has that been done? I don't know what minimum tire psi is for this one, but lowering if possible, but yes also run XL tires if possible, and rotate very often, they are terrible.
Return to “Ford Cars”
