Update 8.5.02
- megoff
Re: Update 8.5.02
If you're constantly having reset, please contact support so we can collect logs. Resets should not happen while the software is open. Are all computers in the shop running off the same user? Is it one computer that you first notice the resets on?
Re: Update 8.5.02
FWIW
Ok, so with the help of product support fellow (Benjamin), we discovered that 4 of the 5 stations we use were signed in as DEFAULT USER. So, he/I changed this and each station is signed in as a separate user. So far, it seems that the system is happy. We'll see how long this may last.
Re: Update 8.5.02
We have 2 computers. Did an oil change this morning. Print ticket from host. Walk to car to do something, walk back to host all columns have rearranged and the hidden ones are also back. That's all the info I can think to give you.
Re: Update 8.5.02
Do each of the PCs with Manager SE have their own unique User profiles or are they using the same one? Are either of them displaying Default User?sbebenelli wrote: ↑Mon Mar 06, 2023 6:55 amWe have 2 computers. Did an oil change this morning. Print ticket from host. Walk to car to do something, walk back to host all columns have rearranged and the hidden ones are also back. That's all the info I can think to give you.
Re: Update 8.5.02
We are a father, son shop. We only have one user setup and never log out of it. I just looked both say the same user. (My name)timbre4 wrote: ↑Mon Mar 06, 2023 6:59 amDo each of the PCs with Manager SE have their own unique User profiles or are they using the same one? Are either of them displaying Default User?sbebenelli wrote: ↑Mon Mar 06, 2023 6:55 amWe have 2 computers. Did an oil change this morning. Print ticket from host. Walk to car to do something, walk back to host all columns have rearranged and the hidden ones are also back. That's all the info I can think to give you.
Re: Update 8.5.02
Because more WIP settings belong to the user profiles now, it is probably going to be necessary to have unique User profiles on each PC. When time permits, turn the second PC off and create a new USer profile. It will want to go back to default view and you'll need to make the changes to replicate the view that you had (or close to it), maybe make some changes you wanted to make.sbebenelli wrote: ↑Mon Mar 06, 2023 7:06 amWe are a father, son shop. We only have one user setup and never log out of it. I just looked both say the same user. (My name)timbre4 wrote: ↑Mon Mar 06, 2023 6:59 amDo each of the PCs with Manager SE have their own unique User profiles or are they using the same one? Are either of them displaying Default User?sbebenelli wrote: ↑Mon Mar 06, 2023 6:55 amWe have 2 computers. Did an oil change this morning. Print ticket from host. Walk to car to do something, walk back to host all columns have rearranged and the hidden ones are also back. That's all the info I can think to give you.
When that is done, restart Manager SE on the second PC and select the new profile. This sequence should prevent conflicts or a reversion back to a default layout.
Re: Update 8.5.02
So leave each computer with the different user logged in?timbre4 wrote: ↑Mon Mar 06, 2023 7:12 amBecause more WIP settings belong to the user profiles now, it is probably going to be necessary to have unique User profiles on each PC. When time permits, turn the second PC off and create a new USer profile. It will want to go back to default view and you'll need to make the changes to replicate the view that you had (or close to it), maybe make some changes you wanted to make.sbebenelli wrote: ↑Mon Mar 06, 2023 7:06 amWe are a father, son shop. We only have one user setup and never log out of it. I just looked both say the same user. (My name)
Re: Update 8.5.02
That's what I would do. Your preferred screen layout can be the same (or similar) for both Users.
Re: Update 8.5.02
For what it's worth, we had many days of frustration with the WIP screen until I found out that each station must be assigned a different user. Once I got each station a designated user, the WIP issues went away, at least, so far. We all like the flexibility offered in the current set up. Each user can customize the screens the way they want it.sbebenelli wrote: ↑Mon Mar 06, 2023 8:21 amOK will do that. I'll let you know if I have anymore issues. Thank you.
Yea for Mitchell1 Tech Support!!!!!!!
Re: Update 8.5.02
Well, I have 3 different profiles for myself. The one I use the most is set on more than one computer. It has never defaulted. Another profile I have on the host machine only; no other machine. That profile has defaulted many times.
Re: Update 8.5.02
We did this. It has worked up till today. I turned the host on this morning and the WIP columns are all rearranged. The hidden columns are back on the screen. Columns are resized.
- megoff
Re: Update 8.5.02
We are still looking into what's causing this as we are getting reports of it happening randomly. With something that happens randomly it can be quite difficult to pinpoint what's causing this to happen.sbebenelli wrote: ↑Fri Apr 07, 2023 5:32 amWe did this. It has worked up till today. I turned the host on this morning and the WIP columns are all rearranged. The hidden columns are back on the screen. Columns are resized.
This is actively being looked at.
Re: Update 8.5.02
Can't be fun. Like that customer who has a noise but we can't duplicate it. Gotta love those....
- nickscarcare
Re: Update 8.5.02
I have both of my stations logged in as my user, and they both work and do not reset.
Re: Update 8.5.02
We have 3 stations each logged in all the time and with no issues since we identified each station as a separate used. Hopefully this is the end of our column issues. For several weeks it has been trouble free. (Cross my fingers)
Re: Update 8.5.02
Now a new problem developed. When I want to make a new estimate/work order/invoice/special order and populate the customer screen, there is no name - only phone number. Even after trying several times the customer names do not populate. At random through the day it may function normally but often not. Frustrating.
- megoff
Re: Update 8.5.02
ShopManTim,
Please right click on the phone number and go to column chooser. The columns may have been accidentally hidden.
Re: Update 8.5.02
The column is there - just white with no names. If I right click - nothing happens. If I double click and I know the correct phone number, I can open up the customers vehicle list. The issue is where I do not know the phone number and the name column has no names.
- megoff
Re: Update 8.5.02
Sound like this would be something we'd need to look at as this seems a little strange. Please give tech support a call and we can look at what may be causing it.
