DELETE IF I MISSED THIS TOPIC, BUT, WHEN WILL I BE ABLE TO DECODE 2023 VIN'S?
THANK YOU
2023 VEHICLE VIN DECODE
Re: 2023 VEHICLE VIN DECODE
This should already be possible for most all 2023 models.
1. Check the version # in the lower RH corner of the screen - should say MANAGER SE 8.5.1.419
2. Sounds like you're on an earlier version; go to Help menu > Check For Updates.
3. Download and install the update.
I AM ON THE ABOVE VERSION WITH NO UPDATES AVAILABLE. ANY OTHER IDEAS? THANK YOUtimbre4 wrote: ↑Tue Jun 20, 2023 11:01 amThis should already be possible for most all 2023 models.
- megoff
There should be an update coming out in the near future that will include more VIN data. Please keep an eye on the forum for when the update is released, You'll see the Shop Management Version update at the top of the page.
The current Manager SE 8.5.1.419 release includes these makes for 2023. What are you looking for and not finding?SHARKTOOTH wrote: ↑Fri Jun 23, 2023 9:09 amI AM ON THE ABOVE VERSION WITH NO UPDATES AVAILABLE. ANY OTHER IDEAS? THANK YOUtimbre4 wrote: ↑Tue Jun 20, 2023 11:01 amThis should already be possible for most all 2023 models.
NEW VERSION UPDATED 8.5.2 IS DECODING 2023 RAM TRUCKS. BUT NOW THERE ARE FORMATTING ISSUES WITH SCREENS NOT BEING LEGIBLE.timbre4 wrote: ↑Fri Jul 14, 2023 7:18 amPerhaps there is some factor we cannot see; please provide any examples you might have.brakefamily wrote: ↑Fri Jul 14, 2023 7:11 amI have checked my version and all is up to date... Im still having problems with Vin decoding on some from 2021 and up
THANK YOU
Truck models do come a little later than cars.SHARKTOOTH wrote: ↑Wed Jul 26, 2023 9:09 am
THANK YOU
Text size or overlays? Issue is likely this:
Windows scaling can make the internal browsers display incorrectly or have the mouse offset. We're working to fix that, but for now they can disable scaling for Manager. This might be a bit complicated for users so you can send them to support. QUICK FIX
