2015 Jeep VIN?
kkperformance
2015 Jeep VIN?
Post by kkperformance »
Nothing in the system for a 2015 Jeep Cherokee?
Re: 2015 Jeep VIN?
We have some of the 2015 models in drop-down selection lists, nothing appears on the ProDemand side as yet. I suspect this is a few weeks away and have asked for an update.
Re: 2015 Jeep VIN?
I have received confirmation that VIN mappings (to year-make-models) are now in place for 2015 Jeep models. I'm told to expect these in the next production builds; that translates to an SE update via updater in the next few weeks.
kkperformance
Re: 2015 Jeep VIN?
timbre4 wrote:I have received confirmation that VIN mappings (to year-make-models) are now in place for 2015 Jeep models. I'm told to expect these in the next production builds; that translates to an SE update via updater in the next few weeks.
Thank you very much
kkperformance
Re: 2015 Jeep VIN?
Update 11/17/15 still nothing on this Jeep.
Re: 2015 Jeep VIN?
kkperformance wrote:Update 11/17/15 still nothing on this Jeep.
I see 2015 Jeeps; what version of Manager SE are you running?
kkperformance
Re: 2015 Jeep VIN?
6.5.54 Nothing yet for a 2015 Cherokee Trailhawk.
Re: 2015 Jeep VIN?
Version 6.6.10.
Re: 2015 Jeep VIN?
If you would be kind enough to provide the VIN, I'll see if it decodes in the latest version of Manager.
kkperformance
Re: 2015 Jeep VIN?
ricmorin wrote:If you would be kind enough to provide the VIN, I'll see if it decodes in the latest version of Manager.
1C4PJMBS7FW510160
Jeff @ Able Auto
Re: 2015 Jeep VIN?
Post by Jeff @ Able Auto »
KKPerformance you should get the update. Decodes ok in 6.6.10
kkperformance
Re: 2015 Jeep VIN?
Jeff @ Able Auto wrote:KKPerformance you should get the update. Decodes ok in 6.6.10
We have not received the update yet. Our current is 6.5.54 and shows no updates available
Jeff @ Able Auto
Re: 2015 Jeep VIN?
http://www.m1faqs.com/fix/SE/ Go to this link. Top of page just above blue bar. Follow directions closely. HTH.
kkperformance
Re: 2015 Jeep VIN?
Jeff @ Able Auto wrote:http://www.m1faqs.com/fix/SE/ Go to this link. Top of page just above blue bar. Follow directions closely. HTH.
Thank you very much, did not know an update was available. Every time I check it says no update available. I updated and it decoded perfectly. Thank you again
Jeff @ Able Auto
Re: 2015 Jeep VIN?
Glad I could help.
Return to “VIN Decode”
