Information being cut-off
Just got updated to 7.1.2 by tech support and the workstation vehicle information is not legible it does not do this on the host.
- mitch error.JPG (45.52 KiB) Viewed 5475 times
- mitch error 2.JPG (28.55 KiB) Viewed 5475 times
Re: Information being cut-off
Check your screen resolution settings.
I have it set to recommended setting if I change to a lower resolution it remains bunched but is also blurry.
Can you provide the resolutions between the workstation and the host? It certainly looks like a resolution issue.
Both are the same resolution. my host is not blurry. I'm baffled.
- mitch error.JPG (17.86 KiB) Viewed 5469 times
- mitch error 3.JPG (30.76 KiB) Viewed 5469 times
Huh. Best to give support a call on this one. Maybe something to do with how that monitor achieves that resolution. Weird one.
Monitors the same size?
I'm not sure they look similar but ill check. I'm going to set it to default settings and see what happens.
Your first and third pic you shared have the same filename so their likely the same picture. Just making sure the two machines aren't using different resolutions.
That was an accident on the pics. But the resolution says the same for both screens. Ill try to set to default if it has t or make it smaller and see what it does.
Checking the resolution is the first step, and you've covered that. The next component of display issues is DPI. That looks like Windows 10 from your screens, so look for the bar with the slider that says "Change the size of text, apps and other items." Chances are the one with problems is set to 125, 150 or some other odd number. Try to set it back to 100.
That is probably the case. Ill check it out.
Ah yes. I completely forgot about DPI.
It was set at 150% it is way to small at 100% so I put at 125% and all seems ok. Thanks everyone. Its weird it happened after the update. Maybe due to the new layout.
Thanks for posting your results. Hopefully it'll help someone else some day.
