Here is an example of what i'm trying to do and i can't seem to make it happen correctly.
Old part # 1234
New Part # 5678
When i log in to Napa Prolink and look up the part (that we stock and have in inventory) sometimes we forget and select the old part.
When importing it from Prolink in to Mitchell it just adds the old part normally. (I've tried setting up a Superseding part and had no luck)
I would like when i select Part 1234 in Prolink and import it, that it automatically adds part 5678 to the RO.
So i setup Alt parts, and this had no effect.
Even if i would type in 1234 manually, it would add part 1234 and not 5678 that i had listed as an Alt Part.
Then i changed the part numbers of the old parts to add a 'z' at the end.
After doing this when i manually add part 1234 it will pop up and offer to add part 5678 instead.
This is perfect, and i'm happy with this.
However when i use Prolink none of that works. It just adds the part using the default Napa name. (Since there is no part in our system with that number after adding the 'z', even though the number selected is an Alt Part)
So how can i get Prolink to correctly select the other part number when importing it to Mitchell?
I've read on the forums, i've looked through the videos and guides, and have not found anything. What am i missing?
Supersede/Alt Parts when importing from Napa Prolink
Re: Supersede/Alt Parts when importing from Napa Prolink
Following...
We had problems figuring how to set up the superseded parts also... We had an oil filter change from Napa - 27050 to 2100082 & we tried to set up the superseded part- it kept trying to restock 27050 instead of the new number 2100082 when pulling a P.O.
Oil Filters are where we are running in to the biggest issues too, We changed over from the Proselect to the Gold on a lot of our filters and have been having issues ever since.
ok, i think i have figured out the source of my problems, but i'm not sure how to fix it.
If you enter the new part, and use the old part number in the ALT PARTS, it will choose the new part when you add from the online catalogs
EXCEPT if the line codes are different.
So for an oil filter #1191 with a line code FIL, it will not find the alt part #21191 if the line code in the online catalog is anything other than FIL.
In my case the line code for the older filter #21191 is SFI, so Mitchell will not allow that part to be an alt part.
So Mitchell, what do i do?
Please know that depending on what kind of relationship you've defined, the rules for Alt part entries can differ from actual part records in your database. The Alt part is an alias for an existing part. To eliminate the issue from changing oil filter lines, I would consider a Supercede for each of these to the new equivalent part you order. That way you show the relationship and if the older number is requested, you get the split screen (old/new #) to select.
Since it wasn't mentioned so far, you might not be aware of this new option in Default Settings in regards to handling parts where there are line code differences:
- subpart.png (13.99 KiB) Viewed 3785 times
Thank you!
I don't believe that Supercede will work with a catalog import, only if you enter the part number manually.
When did that option get added for look for other part numbers?
Correct; the Supercede feature would not work with a catalog.
According to our WHAT'S NEW In The Release? link [home screen] we added the Default Setting option during the SE 6.6.8 release.
