Update to 7.2.x
Update to 7.2.x
I was wondering if the updates are still automatic or do I need to go in and manually update? Thanks in advance.
- a&mauto
Re: Update to 7.2.x
We got a notification on our opening screen when it was available to us.
Re: Update to 7.2.x
I got the splash screen. Just haven't heard when it might be avail.
Re: Update to 7.2.x
The program will alert you automatically -or- you can go to http://www.m1faqs.com/fix/SE/index.htm and get it yourself.
Re: Update to 7.2.x
Thanks Ric. Looking forward to seeing the "new stuff".
Re: Update to 7.2.x
The new version has a working 'check for updates' button. If there are any updates when you click it, you're alerted. The other big changes are the database engine, change ownership button, some scheduler enhancements and a more visible recall notification.Jeff @ Able Auto wrote:Thanks Ric. Looking forward to seeing the "new stuff".
Re: Update to 7.2.x
We got an auto update, I did the update on lunch, took about 50 minutes to do it, however, I had a computer issue in house and had to restart it. I'd think had it went smooth the over all time would be about 30 minutes.
Re: Update to 7.2.x
Found this thread while looking into how to install the update since I've had a "coming soon" screen since July. Is the update available, and is it automatic?
Re: Update to 7.2.x
If you read the thread, I answer both those questions 5 blocks up.Paradigm wrote:Found this thread while looking into how to install the update since I've had a "coming soon" screen since July. Is the update available, and is it automatic?
