2003 Ford TBird - V8 No Acceleration
Frank Panipinto
Post by Frank Panipinto »
Greetings all! Customer complaint is no power or acceleration randomly. It will idle, but
won't get out of its own way. The little wrench light is on and there are 2 DTC's - P2107
and P2110 - both Throttle Assembly codes. The car is misfiring during each episode, but
there are NO MISFIRE CODES. A check of Mode $06 data with Snap-On red brick and Auto
Enginuity software on a laptop shows absolutely no problems. Identifix lists a dozen or more
same symptoms that had bad coils. Tried identifying which cylinder by pulling injector
connectors, however that got a weird response - most cylinders did not show any response
when disconnected. Anyone run across this before or have a suggestion or two?
Frank Panipinto
Frank's Tire & Service Center
Don't make me ...hungry, you won't like me when I'm ...hungry
Re: 2003 TBird V8 No Acceleration
Frank,
I would concentrate on those TB codes first. Errors in thottle control can and will cause misfires. I have the steps here and can fax if you'd like.
Frank Panipinto
ricmorin wrote:Frank,
Any and all help would be appreciated, Ric. My fax machine and server both failed. Will be working on that tonight. Any chance of emailing info?
Frank Panipinto
Can-do. I'll send it right over.
have replaced more than a few throttle body's on these for exactly the same issue.
Re: 2003 Ford TBird - V8 No Acceleration
Yup. The P2110 may lead to that.
Frank Panipinto
Update: Customer needed to use the car. Will post any future information as it becomes avaliable. Thanks for your help...
Frank Panipinto
thanks for not leaving us hanging......
Return to “Ford Cars”
