This car will not start after it sits for an hour to an hour and a half. It will spin over and over.
The warmer the temp is outside the longer it takes to start. Starts perfectly every morning and after sitting long enough during the day. The check engine light is not on, it has plenty of fuel pressure, the spark seems a little weak. We have replaced the ignition module.
Any suggestions?
2002 Olds Silhouette - No Start
Re: 2002 OLDS SILHOUTTE - NO START
HAVE YOU TRIED THE COOLANT TEMP SENSOR?
just for s&g's i would take a compression test before i start it and compare it to the compression when it's warm and won't start.
Well, if that vehicle was here, I would have my scan tool connected when I am trying to start the engine and observe cranking rpms, fuel injector pulse width, MAF, TPS, and other sensor inputs. To specifically target the fault without knowing more details is like asking the doctor what is wrong with me when I get up in the morning when I feel grumpy. Also, what is fuel pressure during those times. Also, does this have an anti theft system that is malfunctioning? On these newer vehicles, there is various issues that can create the symptom being described.
