Hello,
I do alot of Invoices for large companies and have had alot of trouble with sending them invoices at a later time or at all with the PRINT DATE on the invoice. I am trying to find out how i can remove this from the invoice and have it only say the date it was COMPLETED. Any help would be great. Even if there is just a way to remove the print date that would be helpful
Invoice Dates / Dating
Re: Invoice Dates / Dating
Is it possible to just print the invoices as you complete them and send a batch to the company? Then ALL the dates would be correct. Or, highlight the Invoice date and redact the print date with a thick black marker.
I have one company we just email the invoice upon completion. Then we send a statement monthly.
Unfortunately, we need to have the print date visible on the order by law for some areas.
The only issue i have with this is i was in the habit of leaving the order open on some commercial accounts just out of laziness or some other reason. When i did this the date wouldn't print on the order and all i had was the date of the print or the date i closed the order. This became a serious point when i started working on state equipment and the order posted the date after the close of the fiscal year. The Mitchell program became so much easier for me when i conformed to the way it was designed not the way i wanted it to work.
- MRISICH
Did you know that in Report Pro you can choose your date you want displayed on the invoice?
- Report Pro - Customize Invoice Dates
- Dates_On_Invoices.PNG (45.37 KiB) Viewed 4791 times
how Do you get to Report Pro?
You can contact your local rep or call 888-724.6742 x6313 to order ProPack.
You can find more information here:
http://m1faqs.com/fix/propack/
