Enter a Part Kit# as a Part#
Rob@SD-AR
Post by Rob@SD-AR »
When you enter a Part Kit# in the Part Number field (after clicking on the Part Button on the Order/Revision Screen) it should bring up that Part Kit.
Example.
Click on Part Button
Enter ATF in the Part Number Field,
Hit Tab or click on the Description,
Parts kit named ATF should pop up allowing you to choose the appropriate fluid.
Re: Enter a Part Kit# as a Part#
Less likely to implement; please consider these current behaviors:
1. Part Kits WILL appear in the Parts List now when Bundled Option is turned on; this of course does not display choices found within the kit. [no dialog to display this as it's never been called for]
2. Parts can be trained to the "shorthand" (ATF for example) by entering the phrase into the part record with Alternate part function; add 'ATF' as an alternate to each part option you want to see for selection.
3. Just click on the Parts Kit button and your parts kit will display with options to pick as described (all prompts set to YES of course).
Return to “Tips + Ideas”
