Tire DOT Registration
Posted: Sat Oct 24, 2015 7:18 am
by abenton4146
Read an article that within the next few years tire registration may become mandatory. It would be nice to have an area to type in DOT registrations for tires in the event this happens. It would also be beneficial to be able to search for registered DOT numbers sold in the event of a recall. We have never registered tires here, but are thinking about doing it after having no way to notify our customers when we get these recall letters from manufacturers.
Re: Tire DOT Registration
Posted: Sat Oct 24, 2015 9:08 am
by timbre4
This has been on our list for a while: * Submit DOT # for tire over the internet = See ProPack
Bolt-On is offering this capability today as part of ProPack.
Posted: Mon Oct 26, 2015 7:04 am
by nickscarcare
I put them in right after the tire description. I know this still does not help to search for them, we had to go through a bunch earlier with the Nitto recall to find out all our customers. We do right now register all the tires for our customers. I agree it would be nice to search for the dot # somehow.
Posted: Mon Oct 26, 2015 7:14 am
by timbre4
Actually, History - either by using Search button in History OR the F4 Find History function could find these as it reads part or labor descriptions.
For example, if you entered them as DOT 123456, you could enter %DOT and find those in posted invoices.
% is a wildcard to ignore whatever text precedes DOT in your descriptions.
Posted: Mon Oct 26, 2015 7:29 am
by timbre4
Better yet, the Management - Part Number Search report is even easier:
- dot1.png (8.57 KiB) Viewed 4630 times
- dot2.png (20.98 KiB) Viewed 4630 times
Posted: Mon Oct 26, 2015 9:33 am
by nickscarcare
Cool, did not realize this, did that work in 5.9 also? That is when we had to look it up, but is nice to know for future use.
Posted: Mon Oct 26, 2015 11:47 am
by timbre4
Yes it works much the same way in 5.9. The Part Number Search screens are a little different in appearance yet do the same things.
Posted: Tue Oct 27, 2015 2:30 am
by Jeff @ Able Auto
Tim in this case you would have to enter each tire as a seperate part, correct?
Posted: Tue Oct 27, 2015 5:36 am
by timbre4
Jeff @ Able Auto wrote:Tim in this case you would have to enter each tire as a seperate part, correct?
Set of tires is typically a single line; the DOT #s would all need to be entered on that line with a partial description search. [%DOT as opposed to explicit DOT 123456]
If there isn't room for all four, perhaps a $.00 part line to store them. Part # Search doesn't care; History Search reads parts and labor description fields.
Posted: Tue Oct 27, 2015 10:12 am
by abenton4146
Thanks for all the replies. We will try using the DOT in the description going forward.
Posted: Tue Oct 27, 2015 10:15 am
by Jeff @ Able Auto
Thanks Tim.
Posted: Fri Oct 30, 2015 10:27 am
by sbebenelli
Is this how you are saying we should do our DOT numbers so we can search for them?
Posted: Fri Oct 30, 2015 10:54 am
by timbre4
Yes, I'd say so. %DOT would find the invoices with DOT within the description for History Search function. Part Number Search - use the Description "contains" option for returning results with DOT text.
If you want to locate specific DOT numbers, care must be taken to get the input done properly (spaces or no spaces) or use something like %DOT U95% to insure results.
Posted: Fri Oct 30, 2015 1:46 pm
by sbebenelli
OK thank you
