Undo Option For Deleting Line From Order Tab?
hbt1959
Post by hbt1959 »
When working on the Order tab or Sub Estimate tabs, is it possible to have an undo option? For example, if I delete a part or labor line, I get the "Are you sure box?" which is nice. But say I changed my mind even after click "Yes, I'm sure" and need the line back, having an undo option would make this possible. Is an undo option possible? Thanks.
Nelson D. Beverly
Contact@HarrellAndBeverly.com
Harrell & Beverly Transmissions & Auto Repair
Office: 407-322-8415 / Fax: 407-322-8416
209 West 25th Street, Sanford, FL 32771
Family Owned Since 1959
http://www.HarrellAndBeverly.com
Re: Undo option for deleting line from Order tab
Hello and Welcome to the Forum.
The line item delete warning is as far as this will ever go. Implementing an undelete function for a line item probably won't ever happen. I recommend instead you change your habits. Instead of deleting a line, use Ctrl+X instead. It will cut the line from the order, and you have until your next Cut or Copy function to reverse that decision by pasting the line back in.
Return to “Tips + Ideas”
