We use Google Apps for email and other things related our website and business. Is there any chance of getting integration with Google on the customer database side of things? For example, a new customer comes in, does some work, etc., and gets added to our Google Contacts? There's a myriad of things you could do beyond just this once integration was accomplished.
Thanks!
Mike
Google Account Integration
- Johnny5
Re: Google Account Integration
So I checked this out a bit. Manager can produce a CSV file of customer information. That CSV can be used to populate a spreadsheet designed for Google Contacts, which can then be imported to Google. It's a bit of work, but once done, all you customers would be there. To create the CSV file, goto Reports, Followup, select MM - Create Data Export File. on the History tab in follow-up, set the from and to date to some future date. Change the selection method to "Select by Customer not found in the selected date range, this will produce a list of all customers. Click on Search, then Print. This will open a dialog and allow you to name and place the export file on your harddrive. Modify the spreadsheet to mirror googles example, then import into contacts.
See https://www.faithinmarketing.com/2013/1 ... e-headers/
See https://docs.google.com/spreadsheets/d/ ... edit#gid=0 for example of spreadsheet format
Actually, I already do this very thing, but it certainly isn't the ideal "integration." I appreciate the feedback, though. So, my feature request still stands.
