Plate Number - Vehicle History
sbcauto
Post by sbcauto »
here is a request. when customer Buys Another vehicle and keeps his history from other vehicle. I pull up his vehicle card, change vehicle information. however when I bring up history on that plate, all history shows up. my last program kept the vehicle and plate history separate. if I check to see if a part is under warranty I have no way of knowing if this was his old vehicle or his new one. is there a work around or can we add this to possible updates?
Re: plate number
I'm assuming the same plate moves to a new vehicle.
If that's the case, you should clear the plate from the existing vehicle, then create a new vehicle record and add the plate to that. This way, when you view the customer's history, you will clearly see each vehicle.
Return to “Tips + Ideas”
