Changing Ownership
veldman
Changing Ownership
Post by veldman »
Is there a way to change or add the location of the change ownership tab. When you are adding a new vehicle to a customer and enter in the vin, if it was someone else's vehicle it will bring up a small screen that says it belongs to this other person. Is there a way at that point to say change ownership if you want. Otherwise you have to back out, search it and it could be from 7 years ago and have to search through and find it. It would make that process simpler.
Re: Changing Ownership
We agree the Change Ownership could be improved and you will see an easy to find toolbar button and a more streamlined process in the Manager SE 7.2 release. :wink:
EDIT: That would be a workflow improvement; would require some additional development work.
sbcauto
Post by sbcauto »
Go To Utilities, Go To Vehicle Screen; Put In Vin Number, Decode, Window Opens, Click Ok. Bottom Of Screen is Change Ownership. That Is Quickest Way That I Found To Do This. Hope That Helps.
Return to “Tips + Ideas”
