Storage Charges
Storage Charges
is there any way for the POS to keep track of storage charges? for instance time stamped date of drop off, last contact with customer. duration of stay (idle time/ awaiting pick up). And if so would that be a new labor category? Sublet?
The Hudson Valleys PREMIER Alignment Shop.
- Pauls Automotive
Re: Storage Charges
As far as tracking I created one called "Storage of Vehicle". I also created a canned job called the same. I manually type out in a labor window the beginning date of storage and the rate per day. I clean a running tab (manually) until it is picked up. There is no functionality biult into Mitchell for this so you have to work around it.
