Warranty Repair?
Posted: Thu Aug 18, 2022 2:15 pm
by slowtech
does Manager have a warranty processing option. For an example, if a part is defective and a tech gets paid additional time to swap it out. A separate warranty invoice for tracking.
Re: Warranty Repair?
Posted: Fri Aug 19, 2022 3:11 am
by ShopManTim
What we do here is to have a separate labor line for warranty labor and that way it can be tracked. We also use it for a comeback job as well.
Posted: Fri Aug 19, 2022 7:50 am
slowtech wrote: ↑Thu Aug 18, 2022 2:15 pm
There is tracking for all comebacks. Select the Comeback box when entering the Symptom on the Order. There are relevant reports.
There is no separate invoice. Simply process the order as you would normal tech pay. You can zero out the part in any way you like.
Posted: Wed Aug 24, 2022 10:23 am
by slowtech
We do process the invoice as normal with prices zeroed. The problem is mostly with parts that were defective and didn't make it to the door and needed to be re-replaced. These have been sensors, actuators etc. I had hoped for an internal "crap part" tracking method. With the shortage of supply. It comes up more often.
