2003 GMC Yukon - Brake Line Identification
nickscarcare
Post by nickscarcare »
1GKFK66U73J313325 I am trying to find a diagram of the abs module that shows where the brake lines go to. All I can find is ones with only 5 ports at the module, and the Yukon has 6 ports, one line for each rear brake. It is near impossible to try to trace these things without dropping the fuel tank.
Re: 03 GMC Yukon brake line identification
I just looked, all we have is the 5 line diagram. Sorry
nickscarcare
Yep and that is all I have.
JBUTITTA
Post by JBUTITTA »
The line id should be etched into the ebcm next to the proper port. its not a deep etching so it maybe hard to see but if its oe it shoulb be there. hth. Jerry
nickscarcare
Jerry, in the rust belt here anything is near impossible to read. Rich, no that one is not correct either, I did find that one.
nickscarcare
Re: 2003 GMC Yukon - Brake Line Identification
Is there any way the folks at Mitchell can see if there is a look up for this? Or just forget it?
nickscarcare wrote:Is there any way the folks at Mitchell can see if there is a look up for this? Or just forget it?
The quickest route is to just give a call to support.
LazyTurtle
Post by LazyTurtle »
Spoke with the experts here and they gave me this info:
There is a TSB that has a year range from 1999 thru 2007 for this very thing - in 1Search, type in Brake Line, click on TSB Button, Anti-Lock Brakes - TSB Number 13-05-22-001D
If you can't find what you are looking for within 5 minutes of searching, the wrenches here suggest calling in (option 3).
nickscarcare
Lazy Turtle, again that is for a 5 port system, I need 6. I can't imagine it is that much of an oddball, but it must be.
nickscarcare wrote:Lazy Turtle, again that is for a 5 port system, I need 6. I can't imagine it is that much of an oddball, but it must be.
I don't think you read the entire bulletin. Keep scrolling and you'll see the diagram that contains the 6 port system.
6 port.png (25.79 KiB) Viewed 14562 times
https://static.nhtsa.gov/odi/tsbs/2014/ ... 1-7817.pdf
Page 16 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thanks for the info Ric!
nickscarcare
Ha I just went back and looked again, and I only get 8 pages of that TSB. I went in through a different source and yes it pulls all of it. Great technology when it don't load all the pages.
nickscarcare
I was just trying to figure out how to get the picture resized, to load it on here. That is what I came up with after trial and error of blowing air through one line with the ends cut off. I figured there had to be a diagram somewhere.
nickscarcare
Thanks for the info though and hopefully it helps someone else.
Return to “GM Trucks”
