1996 Chev K2500 5.7L - ABS Issue
Posted: Thu Jan 02, 2020 11:39 am
I have this 1996 Chevy K2500, a 5.7L engine, automatic trans and 4WD. The issue is that the amber antilock brake light is on in the dash. There is multiple codes in the ABS Module for wheel speed sensor signal missing at all wheels, erratic wheel speed on all wheels, relay circuit shorted, and a watchdog code. When I try to erase codes, they simply do not disappear. I have tried replacing the module with the same results. Same codes and same inability to erase codes. I have good solid power and good solid grounds to the module. And as per MOD diagnostic process, it says replace module. However, that doesnt fix it. What am I missing?
Re: 1996 K2500 ABS Issue
Posted: Thu Jan 02, 2020 12:12 pm
The ebcm? What are the codes? Have you LOAD tested the wiring to the ebcm? Did you program the tire size? Id want to know the ebcm is bad before replacing that way if I got a defective part we would know that.
Posted: Thu Jan 02, 2020 12:24 pm
The codes are C0035 - Rear Speed Sensor Open or Grounded
C0022 - RF Speed Sensor Signal Missing
C0023 - RF Speed Sensor Erratic
C0066 - Open Or Shorted Pump Motor Relay
C0073 - EBCM Memory Error
C0086 - Shorted ABS Indicator Light
C0025 - LF Speed Sensor Circuit Open
C0021 - RF Speed Sensor Circuit Open
As I mentioned, when I replaced the EBCM, I have the same problems, same codes and they cannot be cleared with my scan tool.
Posted: Thu Jan 02, 2020 12:51 pm
You replaced the EBCM with a *new* unit or used?
Posted: Thu Jan 02, 2020 1:02 pm
It was a used unit Ric. "new" and or reman is not available. We even sent the one we took off to a place that can check and rebuild them if need be. They said that there was nothing wrong with the one we sent to them.
I should mention that in viewing data, the wheel speed sensors all show something over 6 million mph. Identical numbers for all. It does seem that the other data is correct.
Posted: Thu Jan 02, 2020 2:11 pm
VIN please?
Posted: Thu Jan 02, 2020 2:16 pm
Also, I did see a TSB for a revised testing procedure for code 66. Did you see that?
Posted: Fri Jan 03, 2020 6:40 am
Did you load test the wiring or just use a dvom? Did you test the wiring to the speed sensors? Have you tried a different scan tool?
Posted: Tue Jan 07, 2020 4:22 am
ricmorin wrote:VIN please?
1GCGK24R6TE151509
Posted: Tue Jan 07, 2020 4:25 am
ricmorin wrote:Also, I did see a TSB for a revised testing procedure for code 66. Did you see that?
I did not see a TSB that is applicable to this vehicle for DTC 66 although there is one that is for DTC 67, 68 that is for the S10.
Posted: Wed Jan 08, 2020 1:19 pm
Tim Martin wrote:ricmorin wrote:Also, I did see a TSB for a revised testing procedure for code 66. Did you see that?
My mistake.
So you replaced the EBCM? yes? There are 2 components that make this assembly IIRC. The hydraulic part and the computer part. I'm wondering if the hydraulic part has a problem which in turn is causing these codes in the computer part. Theory is: something shorted in hydraulic part causing voltage pull-down which wigs-out the computer.
According to the wiring diagram, there is a third player called the vehicle control module. Looks to be an interface for the VSS to distribute signal. That's a suspect too.
Re: 1996 Chev K2500 5.7L - ABS Issue
Posted: Fri Jan 10, 2020 7:15 am
As near as I can tell, the Vehicle Control Module and the Powertrain Control Module are one and the same unit in this application. Correct me if I am wrong. The location is in the left front corner of the engine compartment.
Posted: Fri Jan 10, 2020 7:44 am
Tim Martin wrote:As near as I can tell, the Vehicle Control Module and the Powertrain Control Module are one and the same unit in this application. Correct me if I am wrong. The location is in the left front corner of the engine compartment.
I didn't investigate that deeply, just an observation. It's certainly possible. Gotta love OEM's and naming conventions. If it was the PCM, just call it that.
Posted: Fri Jan 17, 2020 7:40 am
What was the fix for this?
Posted: Fri Jan 17, 2020 11:07 am
brianp87 wrote:What was the fix for this?
Have not brought this challenge back into the shop again. Will post the fix
Posted: Fri Feb 07, 2020 1:53 pm
Any update?
