1999 Chevy C1500 - 5.7 Kicksback, Grinds FIXED
bmadison31
Post by bmadison31 »
Truck kicksback or grinds when trying to start. It will occasionally start. I replaced Crank sensor per TSB (00-06-04-014). I also pulled the Distributor to check the drive gear since I have a lot of these come in with worn out gears no problem found on this one. Truck started perfect everytime I tested it after restabbing the distributor so I delivered the vehicle. Truck got towed back the following day doing the same problem. There are no engine Codes. Any help would be appreciated
Re: 1999 Chevy C1500 5.7 Kicksback, grinds
These are known for cap and rotor problems...moisture? May even be a TSB on it.
ricmorin wrote:These are known for cap and rotor problems...moisture? May even be a TSB on it.
Yea I'd agree. Do not put cheap ignition parts on these vehicles. If I remember there was a tsb on placement for the coil wire.
Re: 1999 Chevy C1500 - 5.7 Kicksback, Grinds
take a look at the flywheel. have had more than a few cracked.
bmadison31
Replaced the Cap and Rotor. Delivered the vehicle appartenly no problems after 4 days. Note: On Cap replacement TSB recommends removing screens in distributor
Re: 1999 Chevy C1500 - 5.7 Kicksback, Grinds (Fixed)
Excellent!
I have a 2001 van here from another shop with a misfire they can't fix. Turns out to be a defective Advanced Auto Parts cap and a fouled plug. Man!
Return to “GM Trucks”
