2003 Chev 2500 HD - 6.0L Runs Rough When Cold
Posted: Fri Dec 10, 2010 1:08 pm
by mitchs
I have a 2003 Chevy 2500 HD with 6.0 liter engine; when I first crank it up, the truck skips and doesnt want to accelerate and also wants to spit back through intake. But when engine warms up it seems to run fine. I have checked fuel quality, pressure, coolant sensor and everything else I can think of.
Has anyone else seen this before?
Re: 2003 Chevy runs rough when cold
Posted: Fri Dec 10, 2010 1:12 pm
Do you get ant fault codes? I replace alot of glow plugs and fue injectors
Posted: Fri Dec 10, 2010 1:19 pm
by mitchs
It is a 6.0 gas engine and only fault codes I get are p0300
Posted: Fri Dec 10, 2010 1:23 pm
by liljoe
Check and make sure the MAF is not dirty.
Posted: Fri Dec 10, 2010 1:24 pm
mitchs wrote:It is a 6.0 gas engine and only fault codes I get are p0300
Sorry I thought I read 6.6L. P0300 is a random miss fire. If you watch the miss fire couters do you see any cylinders that stand out?
Posted: Fri Dec 10, 2010 1:25 pm
by mitchs
MAF is good.I read somewhere that there may be an issue with sticking valves just wondered if anyone else has seen or heard of that?
Posted: Fri Dec 10, 2010 1:27 pm
by mitchs
looks like the whole left bank has random misfires.
Posted: Fri Dec 10, 2010 1:41 pm
Never heard of the sticking valves. There are 2 TSB's that may relate. 05-06-04-029A and 06-06-04-046. I'd check those out first. Also, try doing a crank relearn. That often fixes weird misfires like this.
Posted: Fri Dec 10, 2010 1:47 pm
Never seen a valve issue
Re: 2003 Chev 2500 HD - 6.0L Runs Rough When Cold
Posted: Sat Dec 11, 2010 3:04 am
if i had to guess i'd lean towards a vac leak. a pop in intake usually is a lean pop.
Posted: Tue Dec 14, 2010 4:42 am
by mitchs
I just want to thank everyone for the input. Finally got the truck out of my shop after about a week of on and off testing and finally found that the problem was a fuel quality issue it had an alcohol content of 34% and that was the problem all along.
Posted: Tue Dec 14, 2010 10:05 am
thanks for posting
Posted: Mon Dec 20, 2010 7:03 am
by 92zman
I know then on the 5.3 it is most likly a o2 sensor. I would switch the front sensors from side to side and see if the miss fires switch sides...
