1997 Olds Bravada AWD - Park Pawl?
orthp
Post by orthp »
I have '97 Bravada awd when it is in park it rolls back on a slight hill, does anybody have any ideas ? :lol:
The park pawl is engaged but if you hold a little pressure against the vehicle, it will slowly move? I also have the front drive shaft out
getting it repaired. Wonder if that would have any bearing on that?
:lol:
Thanks Paul
wbuxton
1000 Club: Interstellar
Re: 97 bravada awd v6
Post by wbuxton »
How far will it roll after being placed in park?
William
Weatherford, TX
817-599-7680
866-744-3887
http://www.phoenixtrans.com
i would bet it's the parking pawl that's junk.
orthp
Post by orthp »
as long as you have a light pressure aginst it will move about 1/4 the movement of a snail
:lol:
Re: 1997 Olds Bravada AWD - Park Pawl?
a North American or Caribbean snail?
92zman
200 Club: Major Contributor
Post by 92zman »
Check the T/C see if it is not working right if it has the two speed one. If it does pull the motor off and then put in to a gear yourself and see what happens then
orthp
Post by orthp »
the transfure case only has 2 sprockets and a chain it is not 4w drive it is awd all the time no disingaging it. 8)
probbly Norh American Steve. :)
92zman
Post by 92zman »
does it have smattrack if it does it is a two speed t-case. When it is not being needed it is in two wheel drive and then when u do need it it will go in too 4-wheel drive
Return to “GM Trucks”
