Chev 454 Exhaust Manifolds For Motorhome?
Does anyone know of a source for chev 454 exhaust manifolds for motorhomes. Any help would be great. Thanks, Tom.
Re: Chev 454 Exhaust Manifolds For Motorhome?
I may have a pair. Will check in the morning and post. Ok? I know that at one time I had a pair around here in storage.
try dorman #'s 674-159 and 674-244. i did a quick search and used an 1985 cab and chassis. the manifolds are readily available. another source i've used is "steven's exhaust manifolds" i got the # in a "motor age" magazine. when i'm doing a job like this i have an exhaust bender that makes it so much easier to adapt.
- nickscarcare
I have also used Steven's, their number is 1-800-443-2673. They have always worked well for me.
Thanks for the info, I'll check'em out. Tom.
I have a set of used ones that have the air injection tubes in them. You can have them for $50 a piece plus shipping. If you are interested pm me and we'll get together on it.
- fortknoxx
sold?
I still have them.fortknoxx wrote:sold?
I remember seeing a two piece manifold for these that allowed for the massive expansion and contraction on these applications. Can't remember where, but somewhere........
Ain't not ever heard of split manifolds for a 454. If you can, post the company name that makes them.
If I could find it, I would. Damn! It stinks getting old! CRS!!!
..... gettin old..... what's that?
Tim Martin wrote:..... gettin old..... what's that?
Just wait, youll find out soon enough.....
How long do I have to wait?liljoe wrote:Tim Martin wrote:..... gettin old..... what's that?
Am I there yet?
if your idea of "popping a few pills" is vitamins, calcium, and you spike your "o.j." with metamusil your there. it's amazing how we perceive old. when i was 10, 20 was old. now as far as this manifold issue goes i remember the flex joints in the manifolds. i seem to remember them in front wheel drive vehicles more than others. i also remember taking them out in pieces and for the life of me can't remember the applications. i would go on line and look at the dorman line or contact stevens and see if they have an on line catalogue. for years any time i remove a manifold or replace one i oversize the bolt holes a bit. don't use stainless steel or anything above grade 8 bolts. make sure that the bolts don't bottom out. i see many applications that the bolt is bottomed out, does the job for a while and then snaps. as we all know bottomed out usually means it stays but if it isn't a left hand drill bit takes it out. dorman usually includes installation kits and are worth their weight in gold. i remember some older applications didn't use gaskets. it's my understanding the reason for this was the expansion issue. if they don't call for gaskets then i don't install them.
steven kiser wrote:if your idea of "popping a few pills" is vitamins, calcium, and you spike your "o.j." with metamusil your there. it's amazing how we perceive old. when i was 10, 20 was old. now as far as this manifold issue goes i remember the flex joints in the manifolds. i seem to remember them in front wheel drive vehicles more than others. i also remember taking them out in pieces and for the life of me can't remember the applications. i would go on line and look at the dorman line or contact stevens and see if they have an on line catalogue. for years any time i remove a manifold or replace one i oversize the bolt holes a bit. don't use stainless steel or anything above grade 8 bolts. make sure that the bolts don't bottom out. i see many applications that the bolt is bottomed out, does the job for a while and then snaps. as we all know bottomed out usually means it stays but if it isn't a left hand drill bit takes it out. dorman usually includes installation kits and are worth their weight in gold. i remember some older applications didn't use gaskets. it's my understanding the reason for this was the expansion issue. if they don't call for gaskets then i don't install them.
I use paint in this case high temp black
Let's see here now. Is there any chance that steve has reached the definition of "old"? Does he take pills, vitamins, etc?
- fortknoxx
Steve, tell them the story about the time you and Virginia were going to the concert....
