2002 Chev 1500 - 5.3L Code P0300B
Posted: Wed Oct 26, 2011 11:00 am
We have a 2002 Chevy 1500 with a 5.3...the vehicle came in with a rough idle and skip and code P0300b and customer stated vehicle just went from running fine to acting the fool....it showed misfire on about 6 cylinders....we did a complete tune-up and now at 1500 rpms it only shows misfire on 1,2,4 but at idle it shows on 6 cylinders again...it bounces around from showing misfire on 3 cyl to 6.... I will list below all we have done so far with absolutely no help....
Complete tune-up
swapped injectors around still no change and all pressures good
replaced cam and crank sensors...no change
replaced intake gaskets
smoke tested
checked exhaust for converter and 02 sensors
replaced pcm as last resort and took for relearn at dealer.....everything is reading fine and dealer says system is in limp mode and they have no explanation and I find this hard to believe that they have not run into this.
Any help would be really appreciated for we have came to a brick wall on this one.
Thanks in advance,
Dawn
Complete tune-up
smoke tested
Thanks in advance,
Dawn
