2002 Chev Trailblazer - A/C Liquid Line
Posted: Mon Jul 01, 2013 12:10 pm
by Jeff @ Able Auto
I have an 02 Trailblazer 4.2 auto 2 wd. A/C high side port leaking. Not able to get it to come loose from line. Line is no longer avail from GM, none in the aftermarket. Looked to salvage, couldn't find a good one there either. Any ideas, customer wants a/c. Can't see scrapping an eleven year old car for an a/c line. Any ideas? Thanks, Jeff.
Re: 2002 Trailblazer A/C Liquid Line
Posted: Mon Jul 01, 2013 12:16 pm
Jeff @ Able Auto wrote:I have an 02 Trailblazer 4.2 auto 2 wd. A/C high side port leaking. Not able to get it to come loose from line. Line is no longer avail from GM, none in the aftermarket. Looked to salvage, couldn't find a good one there either. Any ideas, customer wants a/c. Can't see scrapping an eleven year old car for an a/c line. Any ideas? Thanks, Jeff.
Is the Schrader leaking and can it be replaced? Do you have the last known good gm #?
Posted: Tue Jul 02, 2013 1:36 am
G.M. only shows suction side
I thought that the port would unscrew from the line but I've destroyed lines taking them out when they are designed to. If it were me I would look on the web sights for the make your own a/c lines. Years ago I made all my a/c lines and for the life of me can't remember the supplier. May have been airco, don't know. They had splices with high side ports in them and all I had to do was use a tubing cutter and fit the splice in then tighten it. You may still find them but have to adapt from 12 to 134. I'll poke around and see what I can find.
Posted: Tue Jul 02, 2013 2:08 am
O.K. got locked in on this one. Murray is a name of a company that makes a/c fittings. Part #'s 16761 and 16766 are splices that are cut and install compression union style. Dorman #'s are 800-966, 800-967. These will work. I saw them on O'Reily's web sight.
Posted: Tue Jul 02, 2013 3:59 am
by Jeff @ Able Auto
Thanks folks. I am gonna take the line off and see if I can get the port to come loose. If not I will look into the doorman repair parts. Planned obsolescence by the auto makers to drive up new car sales? Thanks again!
Re: 2002 Chev Trailblazer - A/C Liquid Line
Posted: Tue Jul 02, 2013 10:05 am
G.M. shows low side only as replaceable. High side port is part of the line.
Re: 2002 Chev Trailblazer - A/C Liquid Line FIXED
Posted: Tue Jul 02, 2013 4:27 pm
by Jeff @ Able Auto
Removed line from truck and clamped in vise. Propane heat for a second and came loose. This was the the liquid line high side charge port behind right headlamp. Installed new fitting and all is good. Thanks folks!!
Posted: Wed Jul 03, 2013 1:38 am
Thanks for posting the fix. Had it been me (the way things are going lately) a June bug would've crawled inside the open condenser port.
Posted: Wed Jul 03, 2013 3:50 am
by Jeff @ Able Auto
It's July, no June bugs left!
Posted: Wed Jul 03, 2013 4:38 am
Alright, a July bug.
