I've got a 2003 F350 4x4 6.0 Auto with a no crank no start.
If you jump the starter it cranks but won't run.Lights,horn and blower work, but no communication to scanner. Have 12v to aldl. Check engine light on. Injectors do not make there normal clicking when key is turned on.Also no reverse lights.
Any ideas?
Thanks
2003 Ford F350 - 4x4 6.0L No Start FIXED
Re: 2003 F350 4x4 6.0 no start
Sounds like one of the primary fusible links either melted, shorted, or got disconnected. That's my first thought. And as I looked at a wiring diagram, that is what I suspect.
Re: 2003 Ford F350 - 4x4 6.0L No Start
Definately sound like power or grnd supply issue, check fuses and links
Maybe an ignition switch? i've seen plenty of those.
Re: 2003 Ford F350 - 4x4 6.0L No Start FIXED
Central Junction Box was the culprit.
Interesting! Did it melt or what?erlesauto wrote:Central Junction Box was the culprit.
