2013 Ford F150 - Starting System Fault FIXED
Posted: Fri Oct 02, 2015 12:13 pm
by bakerauto
Would like input on this issue please. Tried Programming a key on a 2013 f-150. After 3 attempts, nothing. Now I have "starting system fault" on dash. Any ideas? Thanks FIXED
Re: 2013 Ford F150 - Starting System Fault
Posted: Mon Oct 05, 2015 2:02 am
It appears you've locked the system. Were you attempting to program one key? Was this an attempt to replace a lost key? Is there any after market alarm or remote starter installed? As a rule two keys are the norm. Anytime I've needed to deal with a lost key issue I've killed that program and set up two new keys. Any more information would help us to help you.
Posted: Wed Oct 07, 2015 6:37 am
by bakerauto
Problem solved. Found key to be faulty (aftermarket). Had a new key made at dealership. Works fine now. Thanks
Posted: Thu Oct 08, 2015 1:37 am
thanks for posting the fix
